I was wondering if anyone had any additional tips or information about drilling exploratory holes to determine if water is present (under the fiber glass) where the Keel Stub Wood is located in the bilge of a 1977 Catalina 30‘. I want to make sure the wood REALLY NEEDS the repair before I go through all the work of removing/repairing the old stub wood. I do have a "Catalina Smile" in the front part of the Keel (hull side) that has been previously filled or caulked with something, and no water is present in the bilge. The keel nuts are a bit rusty because the previous owner(s) allowed water to stand for long periods of time in the bilge. My thinking is that I may be able to simply retorque the Keel nuts (down), then fill in the Catalina Smile (crack) in accordance with the Catalina-Yachts drawing/repair procedure. I have heard someone mention to drill 1/8" diameter holes near the keel bolts, just above the stub wood area in the bilge, to see if water comes out? Does anyone have any recommendations on how many holes, how deep, and where I should drill these exploratory holes? If no water is present, that's a good thing right? Can I assume the wood removal and repair process is not warranted at this time? Also, I'm trying to find a couple (2) Anchor chain caps (for the anchor chain/line that goes through the deck). There is a name stamped on the cap entitled "MARINIUM". I have attached an example photo to this email that I got from West Marine (the difference is that their part is chrome and mine is aluminum). The Catalina Yachts Parts Department (in Woodland Hills) doesn't have the part. Any idea where I can find them?
