I wrote to ask Phil about this on the "Site Talk" board and he restored the posts. He was not sure why they went 'poof'. Apologies to Bilbo if he intended them to be deleted.What halppened to Bilbo's posts? Too long? Or, someone did not them?
OC
No, most all of these were trunk sides as was the C-22, not from the cable snapping. We did repair an O'day Mariner that the cable snapped on and punctured a pin hole in the fore edge of the CB trunk, but most all repairs were to CB trunk sides not the leading edge of the trunk. In almost all cases the boats had sunk as a result of damage. In a few instances owners caught it as a small weep first but most found their boats on the bottom. If you have a CB boat periodic inspection of the cable and replacement is a good practices because these can fail too.. If you think it wobbles like crazy up you should should see what this can do with a 5' lever point loading the trunk to only the width of the CB, rather than along its entire raised length.. I have physically watched and listened to CB slam on certain boats and watched as the trunk flexed near the pin.While I respect Maine Sail's opinion, I disagree with him on keeping the Catalina 22 swing keel up while in a slip. If you raise the keel so it's hanging on the cable while on the trailer you'll see it wobbles like crazy. The keel pin will wear the keel fast. I'd like to know if the C22 they repaired had the cable break letting the raised keel slam forward and damage the keel trunk on the boat the yard repaired. This is the usual thing that happens to the truck on the swing keel C22.
Anyone know why he removed them? We restored them, per request, but the vanished again..Probably off-topic, but Bilbo's posts were restored, but are gone again :cry:. This time I will not ask that they be restored, since I do not know if it was due to Bilbo's wishes :neutral:. Sad to lose the inputs.
OC
When I first saw it - I thought that it must be a software glitch - or even - gasp - a moderator error. If I had known that is was the poster's wishes - I would never have asked regarding it. My apologiesAnyone know why he removed them? We restored them, per request, but the vanished again..
