K
ken schwinger
I have a 18.5 Hunter with a wing keel that has minor rust on her. I am going to sand away the rust then paint it with barrier coat followed by bottom paint,the only problem is the underside of the keel. I need advice on how to get to the bottom of the keel,when its on a trailer without using a travel lift? Or maybe I should just forget about the underside as the first time I run up on some sand I will just scrap of the paint?
