The keel lock bolt. Another Catalina 22 enigma. No one, to my satisfaction, has ever come up with a logical reason for this troublesome apparatus. While not as dangerous as the pigtail, but slightly more useless than the "slide out galley", it by consensus causes more damage than it prevents.
By the very physics of this arrangement, it cannot hold the keel in ANY position, either up, or down. The keel weighs in at 550 pounds, and that little half inch bolt, held in with a teacup of fiberglass, roughly one foot from the pivot point, well......Broken fiberglass, bent "lock down bolt", or the usual gouge in the keel is the typical result. I've even heard said that in a FULL CAPSIZE, that the bolt would prevent the keel from pivoting back down violently, crashing through the hull, while simultaneously wrapping the cable around the childrens necks, and dragging them to the deep, to be slowly consumed by sharks.
OK, maybe not the child and shark thing, but I have heard the rest of it. But in all my life, I have never heard of a C22 rolling completely turtle, and if it did, as said earlier, you've got an ass load of problems, and that keel is kind of low on that problem list at that moment.
I kind of hate to admit that I have had the boat in such a pitch, that the keel did bump back down, but I have. Not much, but I'm an idiot, and I've had two other very competent and able bodied seaman at the time. I actually can not recommend this behavior. But when I do, I keep the keel cable snug, as to help absorb the shock.
The only relevant excuse that I've ever heard, (at least that makes sense to me), for that bolt is, that it was some sort of liability issue at one time for the manufacture of this boat. The only thing that Catalina has had to say about the thing is, "lock the keel bolt". No reason why. And Catalina would have to have some very compelling reason for it, to re-install one in the boat..
