keel hanger
stan
I just purchased a 1983 Cat 25 swing keel model. The winch cable is broken as part of the maintainence the past owner told me to replace the cable every two to three years. Should the keel hanger assembly including pin be replaced, it is 20 years old?????
bob
check it out
with the boat on the trailer you can place a floor jack under the keel below the keep pin an take up the weight. You can then remove and inspect the castings and keel pin for wear. it depending on amount of use, however under normal conditions I would think the keel cable should last well over two years - it is easy to inspect and replace. Happy sailing, Bob
Ted
Inspect yearly . . .
but I don't think replacement every few years in necessary.
Catalina 25-250 Association
Stan If you haven't already you HAVE to meet these guys. See the link. Stu
G
Greg
a lesson on me
JUst dropped the keel on my 22 for first time in 20 years. The keel pin was sawed halfway through. Look at yours NOW!!!
