matt
just a thought, for those of you who have replaced the keel pin, just how much vertical play is there in the keel when the new pin is in place and there is no wear in the system. in looking at older 22s it seems that a quick easy method for possibly determining problems before purchase and without the expense of a lift would be to simply slowly jack the keel up a bit to determine how much play is in there. i presume that an elongated keel hole or worn pin would show up with excessive play. does this sound ok and if so how much play would be ok and when would you think there was a problem? (numbers would be good. 1/16th" 1/4".....)basicly i accept the replacement of the pin but i would like to avoid a boat with the keel hole elongated. thanks in advance
