Just did them
When I had to do mine I called Catalina Yachts and they gave me the torque recomendation. With the boat hauled out and sitting on the keel the torque is 120 lbs pounds for a Catalina 30 1980. They should be similar but if not sure then you could call Catalina Yachts at 818-884-7700. I also know if the nuts and washers are not properly sealed water can seep down them and cause corrosion between them or water can seep under them and cause the wood under the glass to rot then you have a worse problem. After I cleaned the studs I bought new nuts and washers and sealed them with 4200 between the washer and the bilge floor, between the washer and the nut, and after I torqued them I sealed the top of the nut by the threads. That prevents and bilge water to get in them if you do not have a dripless packing. Hope this helps, John
