keel bolts
What boat?
If the Mac 25 are we talking pivot pin or lock down bolt?
Feb 8, 2014
1,300
Columbia 36 Muskegon
For the bigger stuff that the local hardware doesn't have, I go to wholesalebolts.com or boltdepot.com. Between the two they have darn near everything, both SAE and metric.
Oct 28, 2019
4
Hunter, Macgregor 25 and a 30 Myrtle Beach, SC
but you have to have a rubber bushings and convex washers
dLj
Mar 23, 2017
3,417
Belliure 41 Sailing back to the Chesapeake
For your pivot pin I'd look for 17-4 PH stainless steel bolts, if you can find the size you need. McMaster carries some sizes. I don't know what your lock down bolts are on your boat.
dj
I made my own gasket once for the pivot pin on a balboa 26. I made a dam out of masking tape around the edges of a washer and filled it in with goop. See picsgasket.jpggasket2.jpggasket3.jpg
