C
Clive Bond
I'm in the process of purchasing a Catalina 30(1977 model)with 5'6" draft. It had recently been sailed from US to Australia.It has many small blisters which I feel I can cope with by grinding and filling. However it has a hairline crack where the Keel joins the hull. When the weight was lowered onto the keel there was a dribble of water along the crack. I think that someone has previously tried to tighten the bolts.Can anyone tell me if the keel bolts are steel or Stainless steel? Can the bolts be easily replaced? If so - How? Is this a common Problem? Should I walk away from this boat? The rest of the yacht is in excellent condition and represents good value. Thanks, Clive. clivebond@hotmail.com
