Cvicek, what kind of boat is it? If the keel lead
or iron?Have you got any pictures? Is the boat blocked so the keel is back in place, with plenty of boat weight on it so new bolts will hold it on?If it's lead you can do the Catalina fix; drill new holes, screw in new 10 or 12 inch stainless steel lag screws (wood screw threads on one end, machine threads for a nice big nut on the other end).If it's iron, there's a good chance the bolts go all the way through the keel. You will have to pick away at the bottom of the keel, looking for filler, to find out.If it's lead and you decide to use new lag screws;Drill size is very important. If you don't want to do a lot of research, you could use the same size as Catalina uses and use the size drill they reccomend.When you drill down through the lead, you need to clear the chips out of the drill bit VERY OFTEN. If it clogs and sticks, it may not come out again.You need to put big washers on the inside, if the keel stub is strong. If the keel stub has old, soft wood in it. You need to cut the glass over it, clean it out, and put in new glass, maybe 1 inch thick at least. It's not a very big area. If you want more detail, you can email me at waterrat@island.net
