Here is what I did.
I had to replace the keel bolt, the four SS bolts holding the keel to the hull, the eyebolt that the cable is connected to and the cable itself. Did it all within about 1.5 hours. While the botat was on the trailer I first removed the four bolts (used a spanner with the correct sized socket - you should be able to get it off by applying a little force with your hand and arm. If you can't get it with this I would try a gentle tap with a rubber hammer. I fthis doesn't work you may need the help of a mechanic. If a bolt breaks off you have a somewhat bigger problem but not a huge one. I built a 'U' shaped brace out of 2X6 about a foot high and just wide enough to slip over the keel just under the keel bolt. A small jack under the U brace (car jack would probably be fine) and put a little pressure on the jack against the U brace. This will catch the keel when the bolts come free. With the bolts out lower the jack to expose the pivot pin and replace if necessary. Also use new bolts when putting the keel back. A little loctite is also recommended on the threads of the bolts. This went along without incident. Then using two samll jacks I jacked up the back of the boat (put a piece of 2X8 between the jack and the boat to protect the hull. Jack a little on one side then the other just to keep the boat balanced. (be damn careful here - if you can jack without being under the boat this would be best). Once the rear end of the boat is up about 8-10 inches in the the air I climbed into the boat (once I got my confidence up) and lowered the keel to rest on the trailer support. Then removed the winch to get the old cable off - remember how the old cable winds on the winch - you will need to put the new one back the same way. I replace the old eye bolt and attached the new cable to the keel, pushed the wire up through the volcano and then reattached it to the winch and reinstalled the winch. The book from Catalina Direct had all the info I needed although it wasn't spelled out exactly but after studying the relevant sections and visualizing how things worked it was a piece of cake. I ddi it myself but would have been helpful to have another person at the time. Just be careful, go slow and plan it out before you start. If you are at all handy with a socket, hammer, saw, screwdriver you should get along fine. I also found it helpful to take a few pictures with a dig. camera of the old setup as I was taking it apart. This helped as I was going back to reconnect the news stuff. The pivot pin and eyebolt I got from Catalina direct. The SS bolts I got from the local marine store and the cable I got made from the local wire rope shop. Fortunately I live on the east coast of Nova Scotia and a lot of marine rigging shops have setup here to support the offshore gas projects. I really think I saved a bundle going locally. That's my story let me know if you require any detail on any step within this process.
