Starting to think about spring boat jobs, one of which is inspecting keel bolts. After re-reading all the posts on how bad the keel bolts can get I decided to add two keels bolts to my boat using the windowing technique. These would go in between the two pair of existing bolts.
Existing keel bolt inspection. I'm thinking of drilling a small diameter hole right next to and parallel with an existing keel bolt down through to the lead exposing just the slightest arc of the threads of the bolt. Hopefully, this would give me a look at the condition of the keel bolt in the area going through the bottom laminate of the hull. I would then apply wax to the exposed threads and fill this hole with epoxy after the inspection. One point of information is that I have eliminated the plywood stub and added glass per the Catalina drawing and specifications. This makes it much easier to perform the inspection as stated above. This approach seems a whole lot easier than, heaven forbid, dropping the keel.
Thoughts?
Thoughts?
