Hello all,My previous boat (1977 Cal 34 III) had a dropped in lead balast glassed into the keel so I am new to the bolt-on type.I see the keel bolts, however was wondering how they build up the strength of the hull where the keel is attached. What type of problems occur with the keel / hull connection? Should the joint between the keel and hull be faired out with epoxy? What type of maintenance is needed?Opinions and advise appreciatedThanksGreg1986 P36-2
