Sean Herron...
Hello,Thanks for answers to date, I built power boats and sailed dinghies, this being my first lead sled (with sails), mostly affirming what I assume...Next question, I just finnished machining an aluminum interface plate allowing me to rehang my 4 stroke on a properly rated mount, onto the factory transom wedge, new mount wider than wedge...How did 'they' fasten that wedge, before I go into it myself, are all four holes thru bolted, cause my upper holes on the too small mount look like hex lags, but they could be 'threaded' and thru to the transom core, any ideas...One way or the other I have to re-hang the beast, so whatever I encounter I will deal with, just curious, perhaps someone has done same and seen what corners had been cut at the factory, 1977 Oday 22...Again, thanks in advance, I am on a 'make it safe and reliable, and decorate it later kick, an ex-boatbuilder no longer doing it for 'the man'...Am I making any sense...I can post a photo of this thing before I '5200 it onto the boat...Burp...Cheers...SH.
