Just whistle
3,815
Pearson/ 530 Strafford, NH
Hi gang,
Anybody using a fuel whistle on their fuel vent line? I bought one several years ago and it was missing until today. It was in a box with several other items I didn't want to misplace. It would have been funnier if there were two or three socks in there, too.
Anyhow the vent is next to the deck cap and I haven't felt at ease while filling the tank not knowing how close to full I'd get. The fuel guage is at the nav station so I rely on my Corporate Operations officer to give me an interpretation of what the guage is reading. I then listen for the gurgling sound to change especially when she says it's full. Sometimes I pump another ten gallons.
I'm thinking the whistle would be a big help.
All U Get
Ross
Jun 15, 2004
14,693
I always fill from a jerry can. I slip a small diameter hose over the vent on the can and down the filler pipe about a foot. When the tank fills to the vent hose the can stops pouring fuel.
BillyK
Jan 24, 2010
502
Catalina 310 Ocean City, NJ
Now THATS a good trick!
Les
May 8, 2004
375
Hunter 27 Bellingham, WA
Yes, I use the Whistle on my last boat and my present Hunter 27. I find them very useful particularly since my H27 only has a ten gallon fuel tank and the air vent is located on the outside of the hull so that if I overfill, it drips into the water.
However, I find that when using the fuel whistle I need to pump at a good rate, not the very slow that I feel comfortable with. When you fill at a full rate it pushes air out fast enough for the whistle to work. Just a caution. It appears to be fairly accurate--I've never check it out as the fuel gage always reads full when I'm done.
But, yes, I like it.
Johnb
Hunter 37-cutter Richmond CA
My fuel level indicator is way behind the level when filling. I can add fuel, take the level, go for a sail and gain a couple of gasllons while I am out. Just something to know if you are using a mechanical gauge to prevent over filling.
Mar 20, 2004
1,753
We've got a whistle on our 356 and it works really well-very positive indication when to stop pumping-but you do have to pump at a decent rate to move enough air to be noisy
Oct 2, 2008
3,815
Thanks for the replys, I should be able to get to the vent line through the engine compartment. Hope there is room enough. It might go through the cockpit locker which would make it a little tighter. The directions say to install it within 12" of the vent so whatever works.
All U Get
