installation instructions. If you don't have the sprit and rigging kit installed, look at the directions for the halyard block location on the mast and install a block there, run a halyard down the outside of the mast to a cleat near the cabin top. The asymetric chute flies between the halyard and a fitting on the end of the sprit, you'll have to rig something on the bow forward of the jib furler to attach the sail to(usually a block with a line run aft to the cockpit so you can release the sail and pull it aboard). the aft end of the sail has two sheets attached to it, all outside of the stays (when the sail is flying, the windward sheet is idle and goes outside the forestay and the windward shroud)
