Hot!
Brad,I know that it has been as hot or hotter in SC as it has been in NC. You are wise to wait for a cooler day. Especially for the epoxy. I've also had epoxy smoke and bubble... I kept a piece of the cured mess as a reminder! The key to epoxy in hot weather is to use a very broad mixing cup so the mixture doesn't get too hot. That and do small batches at a time. I've been successful mixing up to two-pumps of West System in 90+ degree weather, with fast hardener, but it'd be easier with slow hardener.Good luck with your painting! What kind of paint did you get? I painted my decks, cockpit, cabin sole and cabin walls. It was the longest job I've ever done! As I'm sure you know, the keys are substrate prep (use the proper cleaners and dewaxers for your paint) and the thinner/paint mixture (which is temperature dependent). Get those right and you are 90% of the way to a great paint job.Good luck, can't wait to see how she looks!Cheers,
