Just bought a boat that came with a jib, but I can't get it up the furler, it has no hanks but also no extended track.
Nov 5, 2019
2
catalina 22 catalina 22 Cutchogue, NY
I bought a boat with a furler. The furling jib that was supplied does not look like the furling jibs I am used to. There is no extended flap containing the wire to feed into the track. The wire inside the seam of the jib at the top is too wide to get in the track. I am completely confused as to how to raise this jib and need any help anyone can provide.
What kind of fuller? There are some curlers, I think made by CDI that do not use a foil or track, they furl around the wire luff.
Jun 25, 2004
1,109
Please post a picture of the luff of the jib. What is the diameter of the rope in the luff? Are there grommets in the luff?
What brand of furler? If you're not sure, please post a picture.
FYI, a Schaefer Snapfurl CF-500 uses a 4.5 - 5.0 mm diameter luff tape (aka #5). Most of the other small boat furler brands use a luff tape with a diameter of 5.0 - 5.6 mm (aka #6) . If you have a Schaefer Snapfulr CF-500 a jib with a #6 tape will probably "fit" into the foil if you force it, but there will be too much friction to hoist it.
Yes, Harken, Furlex, Ronstan and others make small boat furlers that require there to be a wire with thimbles on each end ( But not CDI.)
