JRC 1500 Radar
373
Island Packet 37 Hull #2 Harpswell Me
I have a JRC 1500 monochrome radar. After using it for about an hour the screen starts fogging up, which when you are in a Maine fog is not much use, if i continue to transmit it will get unuseable. Any suggestions for a cure? I think its about 8 years old but not sure.
Feb 6, 1998
11,772
You have moisture in the unit that eventually bakes out from the internal heat.. Here's my trick.
Remove the box and bring it home. Turn your home oven on to its lowest setting. Then let it get about 130-140 degrees. When it has cooled to below 130F place the box in the oven and let it sit in the dry heat over night. PLACE A LARGE NOTE ON THE OVEN STATING YOUR RADAR IS IN THERE... ;)
Bring back to the boat and try it. Depending upon how much moisture you may need to do it again as these are supposed to be fairly well sealed.
I have dried out cell phones, watches and instruments this way many times. Hopefully once you get it dry you can keep it covered enough to prevent a repeat.
RAD
Jun 3, 2004
2,330
Catalina 30 Bay Shore, N.Y.
I had the same thing happen with my JRC and I just grabbed the spare unit and used that last season, the fogged up unit got put in the basement where the dehumidifier is and I should check it this year and if its fogged I'll try the MS fix
Feb 2, 2010
373
Thanks for the suggestions, is there something i can do in the long term to prevent the ingression of moisture?
Dec 2, 2003
1,637
Hunter 376 Warsash, England --
I have the JRC 1000 which is the smaller sister of the 1500. Mine fogged up on numerous occasions almost from new. It is on my steering console, out in the wet, though covered by its own sun cover and the tonneau canvas console cover when we are not under way.
I investigated and it was a known problem to the extent that their UK agent, Marconi Marine, took it into their workshop in 2003 and reworked it FOC even though it was out of warranty.
Whether this would still be the case I don't know but you should try approaching the US main agent. Even if he does not do repairs, he might give advice on what needs to be done and so you might open the case and fix it.
BTW I also have Raymarine/Autohelm ST50 instruments and these are designed to leak too. This occurred one very wet day and I saw water swilling around inside my log LCD display. We opened it up, washed it out in fresh water, hung it out to dry and all was well. More recently my depth sounder failed and, when opened there was a 'high tide mark' half an inch up from the bottom of the printed circuit. I bought another unit from a jumble and it was just the same.
So I now cover the four fixing screws on the rear of the case with black tape and then put a band of tape right round the red rubber seal.
Similar treatment might fix your radar!
May 11, 2005
3,431
Seidelman S37 Slidell, La.
JRC
I also had a JRC that fogged up. I called JRC and they told me there had been a problem with some of these units. Sent it to them, had it back and fixed within ten days.
Feb 2, 2010
373
Nice N Easy
How old was the unit when they took it back? and did they completely cure the problem? You got contact info i could use.
Thanks
