Planning to add a galvanic isolator to my dual 30 amp shore power inlets. going with a Yandina unit that can handle the two grounds from each inlet. question is how to best splice the two grounds and join them to the single inlet wire going into the isolator, and then do the same with the two grounds continuing on to the 110v panel. Other than soldering these connections, what would you recommend as the best method of splicing two 10 gauge wires to a third?
Thanks.
Thanks.
