The concern is...
wear on the sails. The chafe caused by the sails rubbing on the lifelines can't be very good for them, and I'd rather remove the lifelines then replace the sails every other year.The sails aren't in the best of shape as it is, and I have no idea how old they are. The previous owner never used the genoa, and only sailed the boat about seven times in the three years that he owned it. I have no idea if these are OEM sails or not. After thinking about it and comparing what I have to pictures, I'm wagering they arent.The reason that I am making an issue out of it is that it doesn't look right. The fact of the matter is it looks wrong, and very wrong at that. I equate it to seeing a car driving down the road with a half flat tire. You know it isn't good for it, and that it's going to do nothing but cause headaches if it isn't fixed soon! Also, the jib sheets have a tendency to get caught up in the lifeline stanchions because the sails are trying to let out past the lifelines. When the sails go up over the lifelines, it has to take the sheet with it. Tightning the jib sheet while it's hanging across the lifeline just puts a lot of pressure on the lifelines. Then, sometimes when I tack, the sheets hang up in the lifelines and I have to climb forward to get them to let loose of the lifelines.The way it is now, it just doesn't fly right. I thought I'd remove the lifelines and store them. If I sold the boat, the next owner can decide if he wanted to put them on. I'm just wondering if ordering some stock sails, which I may do soon, would have any diffrence? If the sails are supposed to be two feet off the deck and mine are not, it would explain more then just this problem. It would explain the placement of the slides so far back. Raising the height of the jib would also raise the angle of where my sheet should tie to them for the best sail shape.In the begining, I had actually thought the lifelines were aftermarket. But after talking here and looking around the net, I'm wondering if it's the sails that are incorrect? It's obviously a problem or I wouldn't have such a fit heh. It might wait until next year either way, because it's not going to be sailed any time soon.I'll measure the sails to make certain of what I have though...that just came as an idea...It's not that I'm against life lines, I'm just against how it and the sail intereact. If one has to go, it's going to be the lifelines.Josh
