Jib sheets - Cow Hitch?
bp
Cow Hitch...What If
I'm a longtime two line - bowline using sailor. To those of you using a cow hitch (and I didn't know that was the name of that knot either) what would you do if your jib sheet parted near the clew and that caused the knot to slip out and let the jib flog. Probably an unlikely event, but what would you do?
Hunter 34 Seabeck WA
You noticed that too, huh Tony?
I like to point that kind of stuff out to anybody who'll listen. Drives my wife crazy!
Jun 12, 2004
1,181
Allied Mistress 39 Ketch Kemah,Tx.
Bp
I would roll up the roller furling. A bit loose, but it would still work. If I didnt have roller furling, i would head into the wind and tie a new line or drop the jib. Probably not much different from your bowline breaking. If you do enough sailing, most of this stuff happens or at least something close to it happens. Last week my roller furling jammed open. We continued sailing while I went forward and unwrapped the furling retreival line by hand. Then I rolled up the jib by turning the drum by hand. We continued sailing with main and then back to the dock. Our guest, that had some limited sailing experience many years ago never even flinched or felt that anything was wrong. The difference between an adventure and a disaster is your attitude. No matter how well you prepare, s**t happens. Tony B
Ross
Jun 15, 2004
14,693
I use two sheets with bowlines at the clew and yes
they do hang up on the shrouds in light air but I have never had them untie. You can tie a bowline inside-out. Then when the tail snags it can capsize and spill. The bowline didn't earn its reputation unjustly. I think it gets bad press from people that tie it incorrectly.
RAD
Jun 3, 2004
2,330
Catalina 30 Bay Shore, N.Y.
Why just today while
Setting up my head sail I secured the sheet with a cow hitch or luggage hitch cause thats the way its been and noticed I need to replace the sheets and thought maybe I should replace the sheets with two and secure them with bowlines, came home to read this post and now I'm confused *o BTW Moved the boat today and had the first sail of the season,it was cold but worth it :)
Jun 12, 2004
1,181
Fred
When I was a real avid woodworker, I read just about every book and magazine on the subject. More than one book or mag had stuff in it that I knew that the author didnt have a clue as what he was writing and there was no way that the technique he was describing could work. It was obvious that he was writing something similar to a book report on other books. Its akin to some instruction manuals wherein the object could not be assembled in the order the instruction manual tell you. Tony B
Dec 25, 2000
6,052
Just a follow-up note...
Actually I tie double bowline knots on my genoa sheets. For those who feel better wearing suspenders and a belt to keep their pants up one could lock the bowline with a half hitch on the tail. I, too have never had a bowline come undone even when the genoa was flogging hard. Terry
Ross
Jun 15, 2004
14,693
If you are terribly concerned with the integrity of a bowline seize the tail to
constrictor knot .
Jun 12, 2004
1,181
Oftentimes....
Gee, i love the way that sounds. Oftentimes, our back-up systems become the problem. Imagine getting hit by a giant 5 lb. knot that cant come apart. It would serve another purpose also. It would be too heavy to lift up and snag the shrouds. Are we all that bored tonite? Tony B
Mar 14, 2008
6
Oday 22 Virginia Beach
Terry, I know what book you read
I read it too... Tag me as one more vote for bowlines.
Nov 12, 2006
256
Catalina 36 Bainbridge Island
Jib Sheet Attachment
I have always used two separate sheets secured with bowlines. I don't consider the occasional hang ups a nuisance. I consider any other method as being un-nautical.
BarryL
May 21, 2004
1,119
cow hitch
Hello, If you don't race or (or change headsails frequently), and have a roller furler, the cow hitch will work great. It can be difficult to undo at the end of the year, but a minute with a marlinspike and you can undo the hitch without damaging the sheet. You can end for end the line, or move it a foot or so in each direction to keep the line from becoming worn in one spot. I have used the cow hitch for a few years now. I find that it is easy to do, doesn't slip, weighs less than two bowlines, makes a smaller knot than bowline, doesn't hurt as much as getting hit with a bowline (or two) and works for me. I really don't care if anyone thinks it 'nautical' or 'seamanlike' or anything else like that. It's my boat and it works fine for me. Barry
Jun 12, 2004
1,181
According to ....
freedictionary.com, anyone that would use the word 'un-nautical' is very unseamanlike. On the more serious side, it seems like most experiences with a cow hitch are positive. Just to be on the safe side, I will apply a seizing. It is very important that I dont get hung-up on the shrouds because with ratlines, it happens with much greater frequency. I was atending a seminar/demonstration by a famous woodworker named Tage Frid many years ago. When asked "what is the best joint to use" he recommended Columbian. Oh well, I just made that up. Anyway, his reply was "use the easiest joint you can make that will still get the job done". I was at a similar seminar with Sam Maloof, another famous woodworker ( he made JFK's Rocking Chair) also way back when and when asked the same question, he gave the same answer. " Go for the Columbian", or was it the other answer. I forget a lot these days. Anyway, I guess the same goes for marlinspike seamanship, use the easiest one that will get the job done. P.S. Dont smoke nylon rope Tony B
Pearson 26W Marblehead
Jib sheets my 2c
I have to agree with Ross & Warren bowlines are the way to go. I always tie them with the bulge away from the stays so they never catch. Im sure using a cow hitch in the middle of one long sheet will work ok, but than you need a set for every jib.
Ross
Jun 15, 2004
14,693
There are several ways to tie a bowline incorrectly
Correctly tied and the tail lays inside the loop and may be seized to the loop with some small stuff. Incorrectly tied and the tail is on the outside of the loop or even worse the tail becomes the standing part.
May 18, 2004
259
J-boat 42 conn. river
ross
if a bowline is made incorrectly, then its not a bowline. as to attaching sheets to a head sail or anything else, why would anyone ever want to use a knot that is difficult to release or undo. all sailing ship knots were designed to hold fast under load but be easy to release when not under load. i sure as hell would'nt want to fight a cow hitch, whatever that is, to get it undone if i had to do it in a hurry, such as when a big blow came up and i had to get it undone for whatever reason quickly. Oh Well, i guess that's what rigging knives are for! S/V Que Pasa?
Ross
Jun 15, 2004
14,693
Capt Jim, If you set out to tie a bowline there are several ways to get it wrong
They are all so bad that they don't have names. A badly made reef knot is a granny. And the bunt line was attached to the clew of a sail on a ship with a buntline hitch. A buntline hitch when drawn up and used under load can only be loosen with a marline spike. So much for easily released knots on sailing ships. One of my favorites is the hatchet bowline.
Oct 18, 2007
707
Macgregor 26S Lucama, NC
Interesting thread...
You all got me to do some research, since no one ever explained what a cow hitch was. My jib sheets are just as they were when I bought the boat, a single line with a lark's head in the center. The Boy Scout Handbook taught me how to tie a lark's head when I was a boy, and I've been using it ever since, when needed. I had never heard of a cow hitch, so I looked it up to find it is the same as a lark's head- and a Lark's foot, Girth hitch, Ring hitch, Lanyard hitch, or Baggage Tag Loop. Names can be confusing sometimes... ;D -Paul
Ross
Jun 15, 2004
14,693
This is my favorite knot page on the web
http://www.animatedknots.com/index.php?LogoImage=LogoGrog.jpg
