Jib Sheet Turning Block-Rail Mounted ????
caltom
Sep 10, 2014
31
Catalina 30 Long Beach, Shoreline Marina
I recently had a local sail maker at my Catalina 30. One point of interest for me was the Jib Sheet Lead Block location. He confirmed what I had concluded, the neutral position is right behind the stanchion forward of the boarding opening in the safety railing.
His suggestion was to mount a cheek block on an angle block about 2 feet aft of the winch on the deck. I decided to take it up with you, The Catalina 30 Pros.
Can I mount a turning block on the Rail using the items shown?
Is the rail sound enough to handle the load?
How much load should I plan for?
Garhauer doesn't specify the load limit on the Track Car. They offer similar blocks like the one shown with various load limits.
Thanks
Tom
caltom
Sep 10, 2014
31
The "Rail" is the 1" aluminum rail that runs down both sides of the deck. The Jib Sheet Lead Blocks are mounted on it.
Yes I want to turn the Jib Sheet from a position aft of the winch.
Mounting a cheek block like the one you linked to are what the sail maker suggested.
Feb 26, 2008
603
Catalina 30 Marathon, FL
Tom,
I'm not exactly sure what you're asking but I think these pics may answer your question.
In the top photo you can see the jib sheet run to a block on the jib car and then back to a deck mounted turning block aft of the winch.
The second photo is a close up of the turning block. All the hardware is Garhauer and stock on our '95 MKIII. I'd be leery of mounting the turning block on a stanchion. There's a lot of load on the jib sheet when the wind is up.
Does that help?
Jim
What you are calling a "rail" is actually called a "track" and cheek blocks aren't mounted on the track but rather like jim's picture. If you have an older boat, then they are placed on the outside of the coaming, almost vertical.
Jim's picture shows the appropriate size, made by Garhauer. Mine are mounted on 1 or 1 1/2" thick wood spacer blocks to make a fair lead to the winch without rubbing on the fiberglass of the coaming.
Jan 6, 2010
1,520
Cal,
Do it the way Jim's pics show it. That's the correct mount.
That turning block will carry the greatest load from your sail. Those flimsy stanchions are not for stressing. That's why I refer to them as, "Lose your life lines."
Make sure you mount a good backing plate below & caulk well.
CR
Oct 29, 2014
38
catalina 30 MKII DCYC
hmm yes yes, I have noticed that my jib sheets come in contact with the side of the cabin and or coaming depending on how they are adjusted.
for folks that dont know my 87 MKII has an additional track running aft along the cockpit, in addition to the track alongside the cabin. I see this was added/deleted over the years, by the factory, when viewing other models of 30's.
I think this is in order for me also to avoid the added friction of the jib sheets in contact with the boat. I have flat turning block way aft behind the aft track track for flying the spinnaker, but that sail is new to me so what do I know!
My wife and I joined an active club in November DCYC.ORG and have been racing PHRF with an active group of J24's. I wonder how quickly tacking is accomplished with the additional turn aft of of the winch with the springy/holdy/turning blocky thingy. Enquirering minds want to know! I will post back after Saturdays regatta as I took them off of my Mac which is waiting to be sold.
Regards,
Nels
1 for folks that dont know my 87 MKII has an additional track running aft along the cockpit, in addition to the track alongside the cabin. I see this was added/deleted over the years, by the factory, when viewing other models of 30's.
2 I think this is in order for me also to avoid the added friction of the jib sheets in contact with the boat. I have flat turning block way aft behind the aft track track for flying the spinnaker, but that sail is new to me so what do I know!
3 I wonder how quickly tacking is accomplished with the additional turn aft of of the winch with the springy/holdy/turning blocky thingy.
1. Outer tracks have always been an option for the original owner.
2. Nope. It is a turning block, simple. Some folks like them, others feel it adds too much friction.
3. Doesn't make any difference. Same line, right? :)
caltom
Sep 10, 2014
31
First off, I appreciate the input and apologize if my question was confusing.
Yes I want to turn the sheet aft of the winch. A deck mounted block is an option. What I'm thinking about is attaching a turning block to the T Track that runs along the rail as seen in the red circle. The other photos are of the pieces I would use.
At 20 knots the load on the sheet would be about 450 lbs. At the turning block it would be about 900 lbs. The SWL of the slide is 2400 lbs and for the block it's 2800 lbs.
This all seems like it should work.
Is there something I'm over looking?
As long as the lead is fair, should work. That picture sure helped. Good luck.
Sep 15, 2009
6,244
S2 9.2a Fairhope Al
correct me if i am wrong here but the load at the turning block would still be 450 it is a 1 to 1 through the block
caltom
Sep 10, 2014
31
Fundamental Concept 3: Pulleys are force magnifiers! When the two weighted legs of the
rope passing through a pulley are maintained in a parallel configuration, the forces brought to bear on the pulley’s point of attachment are doubled!
Sep 15, 2009
6,244
S2 9.2a Fairhope Al
ops i stand corrected lol that is at the attaching point yes
caltom
Sep 10, 2014
31
Yes, I think that is the load on the block and the attachment point. I didn't know this either. It's a part of "Newton's Law" I found while searching for info in this project.
Tom
Feb 26, 2008
603
Hmm, I didn't know that. I've wondered if the deck would support an outer track mounted outside the stanchions...
Thanks for posting Stu.
dj2210
Feb 4, 2012
337
Catalina 30 Watts Bar
Here a picture on my 1990 with the turning block as mounted from the factory. Hope it helps.
606
Catalina 30 mkII - 1987 Alamitos Bay Marina, LB, CA
Here's my turning block aft of the winch... I thought it was stock?
My Jib sheet track is on the complete inside of the safety rail, not like yours at all... I dont' have a pic that shows it...
caltom
Sep 10, 2014
31
Thanks Jonelli. Your turning block is mounted in a fairly typical location. Which is maybe what I should do.
My thinking is if the (rail) Track will take the load why not use it. That way I don't need to add holes to the deck. I can also leave the jib sheet threaded through the block and just slide it forward so it's out of the way for boarding.
We will bump into each other some day. I often walk by to see if you are there.
Tom
Jun 2, 2014
606
Hah. Didn't realize this thread was you! If your jib track goes that far back, why not? Mine doesn't.
And I was just there a few minutes ago grabbing my batteries to replace. Lol
My thinking is if the rail will take the load why not use it. That way I don't need to add holes to the deck. I can also leave the jib sheet threaded through the block and just slide it forward so it's out of the way for boarding.
Tom,
:):):)I guess if "you're workin' on the railroad" the difference between a rail and a track may not make much difference, although purists would take umbrage at the differences between a switch and a turnout. :):):)
It really is a track on a sailboat. :):):)
Maybe since you have one on each side and you looked down from the mast head you could consider them rails...:neutral::neutral::neutral::neutral:
With your outboard tracks your idea will work just fine.
If you chose to install a cheek block, then I'd still recommend doing it vertically to avoid the line rubbing against the cheek of the block, which it could do on the top of Tom's block location.
Good luck.
