shroud tension
I am no expert, but I have been paying attention to this issue after I purchased a Loos gauge this year. It is true that the lee shrouds are supposed to be loose, but I understand that there should not be any slack until the wind is at about 10mph. Someone else may correct me on this. You write that you were in 15 - 17 knot winds, so your lee shrouds should be loose in those conditions. The question is how loose? That's where the gauge comes in handy.Until I got the gauge and checked my shrouds, my lee shrouds flopped all over the place with very little wind. Not good. If you do not have a gauge, you can check the set of your mast with the main halyard. Take enough out to touch the deck on one side, and it should touch the deck on the other side without adjusting the length. To check for and aft, the halyard should hang down pretty close to parallel with the mast, or maybe a little aft, or for, depending on the rake. Of course, that just verifies that the mast is set properly. It does not test the tension on the shrouds.Trevor, I've seen your posts and respect your opinion, but I question whether it is a good idea to take up slack in the lee shrouds while sailing, at least without the benefit of a gauge to test the tension. If they are set correctly, they will be slack at 15-17 knots, and if you take in the slack, wouldn't that throw out the balance? Again. I'm asking for information. (Also, I am assuming cruising like I do, not serious racing with the wheels that adjust tension during the race.)I cannot offer an explanation for slack in the shrouds with the head sail and not with the main up. I will leave that to the experts, but Larry's explanation makes sense to my limited brain power.Again, that is the little I know about it, and many others here know much more and will correct me (I hope) if I'm wrong. I think there are some good descriptions of this process in the archives.Good luckAlan
