Jib Halyard Stuck!
Howler
Jun 1, 2004
10
- - Geneva, Switzerland
In preparing to haul out, I tried to take the jib on a 1995 Hunter 336 down. Even though I slacked the jib halyard and put some real downward pressure on the luff, it wouldn't budge. I examined the head of the jib where the halyard comes out of the mast. Looks clear and free. Threre's a standard Profurl furling system in place which also works fine. I can't imagine what's going on. We bought the boat this season with the rigging up so no prior experience. Any suggestions (other than keep sailing all winter)? Thanks!
E
Ed Schenck
One choice.
You will have to go up there or send someone up. I guess that is two choices. Are you certain the halyard has not wrapped? I had something very like that happen this spring when I got the swivel stuck at the top. I had tried to clean the furler by running the swivel up with a rag attached. A line holding the rag got above the furler extrusion, the raised part that keeps the swivel from going any farther. Then it tightened there. I had a strong messenger line that would not pull that swivel back down. No choice but to send up a yard hand and cut it loose.
