Sag in the headstay can make the furling a lot more difficult, too.
Take up on the backstay or however you tension the headstay if you have B&R rig.
Slack it off when at the dock; I sail with about 1K # on the headstay and in stronger winds take it up to 2K. I have a '95 vintage Harken Mk 2 furler. I admit to sometimes using a winch as a snubber, but rarely. Also our final turning block for the furling line is a small Harken switchable ratchet.
How are your stanchion line leads? If they are "eyes", do change them out for the Garhauer double-sheave leads. Not expensive and they keep the line outside the stanchions and as low as possible.
Regards,
LB
Regards,
LB
