Jib Furling dificult
Mar 31, 2011
62
Leopard 44 Pasadena, MD
Hi All,
I'm new to the "Big Boat" division. I just bought a 2007 Hunter 41DS.:)
I was in a 20kt blow and was trying to reef in the jib and it was almost imposable to pull by hand. I know this is a much bigger boat then I'm use to but should it really be that hard?
I latter checked the reef line alignment, blocks and anything that could have been holding it up but found nothing wrong. I did later spay the drum with silicon spray hopping it would help.
Maybe the jib halyard is too tight or too loose.
Is this normal in 20kts of wind??
Another issue I found was with the Main in-mast furling. :doh:
Some how the continuous furling line clutches (in/out haul) were labeled backwards of the mast furling drum and they had the main sail rolled in the opposite direction.:bang: That was a learning experience figuring that out on a new boat.
TFligh
Jun 6, 2006
6,990
You do have to unload the jib by pinching or letting the sheet out till the jib is almost lufting.
Mar 31, 2011
62
I did release the jib sheets with very little tension on them while trying to furl, and the jib was lufting heavily.
Jun 2, 2011
347
Hunter H33 Port Credit Harbour, ON.
I have a 33 which is quite a bit smaller but I did have an issue one year when I had the jib halyard too tight. In heavier winds it is a little harder to furl in. Try loosening the halyard a little.
Nice boat by the way.
Mar 31, 2011
62
I'll try that, thanks
Apr 11, 2010
982
Hunter 38 Whitehall MI
I've made the halyard too tight mistake before. Made rolling almost impossible.
Another thing I found as I was working through trying to figure out why is that the furling line was rolled onto the drum in the wrong direction. Boat was delivered that way. When I got the manual out I learned that the direction it rolls clockwise / counterclockwise is determined by which side of the boat the line is run and which side of the sail the sunbrella is on. Mine line is on starboard which means drum should roll counterclockwise according to the manual. It wasn't and as a result it overlapped and bound and was hard to roll.
Jun 4, 2004
1,087
Mainship Piliot 34 Punta Gorda
I roll mine up via the power winch when the wind is blowing. Just have to be careful and not put to much pressure on the sail.
May 1, 2011
5,270
Pearson 37 Lusby MD
Try turning downwind so the apparent wind is about 150. This way, the main blankets the jib and takes most of the wind load off. Should make furling much easier.
Mulf
Dec 2, 2003
400
Hunter 410 Chester, MD (Kent Island)
Lubricate the furling parts
When was the last time the top and bottom furling swivels were lubricated?
Mar 31, 2011
62
I just bought the boat and the mast was just stepped prior to purchase, so I would hope the boat yard would have lubricated the swivels. It did seem to rotate with relative ease by hand. But on the other hand, I did find that they had miss routed/tangled the mainsail reef line and miss labeled the main reef line clutches so anything is possible.
My Jib reef line does come off the starboard side and appears to be rolled correctly.
I will definitely try and loosen the jib halyard, I think that may help.
I'll also try turning downwind 150' apparent using the blanket of the main see how that works.
I won't be be afraid to use the winch with a little pressure if I have to.
Thanks for all the great info,
HAPPY 4th
TFlight
Dec 27, 2004
139
Hunter 340 Burlington, Ontario, Canada
Unless you instructed the yard to lube the furling mechanisms they very likely didn't. I lube the lower ends of the main and jib furlers at least once a season and the uppers in the spring before raising the mast. Depending on the type of jib furler you may need to take the line and drum off to reach one of the lube points altho that one doesn't have to be done as often. If you have manuals check those for frequency and instructions. Makes a world of difference...first time I did the main shortly after getting the boat I went from winching to easily furling by hand! I don't think the PO ever did it....
Sep 11, 2011
431
Hunter 41AC Bayfield WI, Lake Superior
Tflight:
I had the same issue as you in very high winds. Since I single hand a great deal, I re routed the furler line from the stanchion mount to a straight in mount and an now am able to use a spare rope clutch and the winch if needed. It has made all the difference. most times hand pulling the furler line is plenty, as the clutch keeps the line form slipping back, but there are many times that the winch comes in very handy for furling the jib.
Apr 11, 2010
982
Tflight: I had the same issue as you in very high winds. Since I single hand a great deal, I re routed the furler line from the stanchion mount to a straight in mount and an now am able to use a spare rope clutch and the winch if needed. It has made all the difference. most times hand pulling the furler line is plenty, as the clutch keeps the line form slipping back, but there are many times that the winch comes in very handy for furling the jib.
I didn't reroute but I did buy a block with attached cam cleat for the line. Serves the same purpose and allows for it to be pulled in without fighting. Attaches to the base of the arch.
Jul 27, 2011
5,144
Bavaria 38E Alamitos Bay
I was in a 20kt blow and was trying to reef in the jib and it was almost imposable to pull by hand. I know this is a much bigger boat than I'm used to but should it really be that hard?
Yeah--it can be (and is) that hard. To help, I eventually shackled a turning block to a pad eye outboard the aft (spinnaker) winch that allows me a fair lead from the final stanchion sheeve to the winch if I need it to adjust the amount of sail out. Otherwise, or to furl in all the way, I just stand up in the cockpit and pull from the block using my weight until the first couple of turns are on; then it gets easier. Last year, I swapped by 135 furlling genoa for a 120--THAT helped a lot!
Sep 21, 2014
28
Hunter 426 Southport, NC
I had a very similar issue this weekend with my relatively "new to me" H426. We were in a 25 knot blow with gusts higher on July 4, I had only about one third of sails out on jib and main. Trying to keep the boat headed up into the wind while I furled at these wind speeds was difficult to say the least. While furling the jib to put it away, I lost control of the furling line and with the sheets only eased she took off and unfurled completely in a matter of seconds. Now we are in a fix with huge wind and a full jib. First things first, heave to for a minute to catch breath and determine best course of action. After a few minutes of rest while hove to, I tried to point back into the wind and furl. The luffing was incredibly strong as I tried to furl, somehow the sail got twisted on the furler and a portion of the sail at the top was still out while rest of the sail was furled. Not wanting to get back into the situation with the full sail out again, I let it be and headed back on course for about thirty minutes. Unfortunately a seam ripped loose and damaged the sail before I could get it unfurled and furled correctly. Couple lessons learned here:
1. Some sort of ratcheting mechanism on the furling line would have been helpful in this condition (maybe that big round shiny thing mounted right next to it) but even a cam cleat or rope clutch would have been a lot of help.
2. Fix problems as they occur, lest they become bigger or more expensive problems.
3. Train passengers to act as crew members.
4. Read this forum every day. Had I seen this thread on the 3rd, it may have helped me out on the 4th.
weinie
Sep 6, 2010
1,297
I was on a friend's hunter 410 last year in about 25 knots of wind when he opted to furl it. Despite warning him on previous trips, he insists on using his winch on the furling line. Well, of course it jammed and the wind was building even higher. His second mistake was to motor into the wind rather than sail off it causing the jib to flog like mad and the sheets to rap themselves into a gordian knot. I convinced him to let me go forward drop the jib completely (he actually wanted to motor into the slip with the jib flailing and the wind honking). Of course, by the time I got the jib down, the jib was ready to go to the sailmaker for major re-stitching along the seams.
Moral of the story... head down wind and let the main blanket the jib to unload the pressure. Then furl. The difference in apparent wind alone by heading downwind is very significant! And don't use the winch!
weinie
Sep 6, 2010
1,297
why didn't you just furl it when you were hove to?
Pat
Jun 7, 2004
1,250
We had the same problem on our O'Day...finally, reading Lay-line from Harken, they
recommended that people have the core removed from the front (first part to roll in) of the line then when you are reefing it in high wind, it rolls on to the spool very easily...It worked...solved all our problem reefing in high winds....the other end (cockpit) end keeps it's core so as to make the line much easier to handle.....it really makes terriffic sense once you put on the new line....West Marine has take the core out of our
5/16th inch line several times....Try it! Good Luck !!
