I know that the furling control line is supposed to enter the drum at a 90 degree angle to the jibstay, but what I never see discussed is where is the best place on the drum, i.e. top, middle or bottom, to have the line aligned with when the jib is furled. I don't like how my current setup has the line loading at the top of the drum, but to change the lead block location (which is currently shackled to the toe rail) I am going to have to drill a new mounting hole, and I only want to do that once. So what works best for you folks?Thanks,Kevin
