Two unrelated problems concerning the Jib Furler and Forestay on a (newly acquired) O'Day23:
1) Just launched last week and am having problems rigging the jib. It seems to jam about 2/3 way up. The jib halyard alone runs cleanly through the length of the foil, but the sail keeps getting stuck. Even the PO came to assist, but to no avail. Any suggestions?
2) I also noticed the Jib Furler seems to be improperly attached. The furler drum opens 90-degrees to port (rather than due aft), which means the furler line rubs against the edge of the drum opening. I think the bottom of jib furler simply needs to be unhooked, moved an inch or so, and reattached to a different position on the bow. But the jib furler also seems to be the forestay.
Is there a safe way to to do this without bringing the mast crashing down? Is it a doable job for one, or should there be at least someone else assisting? Or should I just call a professional for help (and get on their wait list)?
Any advice would be greatly appreciated!
