Our good friend Shermandr has provided us with a topic. He made two statements. The first one was "plenty of cruising sailors rarely if ever adjust their jib leads" and 'he has been on many racing boats, who win, that set their jib leads for a leg of the race and don't micro adjust unless conditions change".
At first I was going to jump all over this UNTIL I re-read the statements - I though he was saying something different that could be misunderstood by newbies. Let me explain. Most boats that I've been invited on to help the boat improve sail trim have the fairleads rusted in place. Fairleads are the first thing I look at because it tells me 2 things -- one is they don't use them and two is I wonder if they know how to use them. By not adjusting the fairleads, they're like the broken clock. The adjustment is right for one point of sail and wind condition and wrong for all others. This is especially a problem on a masthead rig boat where the engine is the jib.
If the boat has pin type adjustors I can understand the problem. Sailors and all humans will do what is easy and not what is hard. It's hard to adjust pin type fairleads under load so they "set it and forget it". They may as well be sailing a 55 gal drum with a broom stick for a mast and a bed sheeet for a sail.
At minimum, a cruiser or a racer should check their fairlead adjustment during each tack and this is how it's done. Just before the boat comes head to wind the jib will "break". Either the top or bottom will break first. It's the responsibility of the trimmer on the loaded sheet to call the "break' to the trimmer on the lazy sheet so he can make the fairlead adjustment on his side before the sail comes over to his side. If the sail breaks evenly from top to bottom, no adjustment is necessary.
At first I thought he was telling me that race boats he's been on don't adjust their fairleads and win races, which is silly, but he 's not saying that. There's nothing wrong with adjusting your fairleads as you sail along. If you have a Garhauer adjustable system, such as I have, the system adjusts itself. When you tack it finds it's own position -- almost. I found I needed to pull the car aft a tiny bit and set up the system so it looked like a minny traveler -- I can move the cars back and forward.
As far as the halyard is concerned, here's how I set mine. I go to full hoist and then back off slightly. I never adjust the mainsail or jib using the halyard -- I use a cunningham for the main and jib.
What do you guys think about this topic??
