Jib construction
297
Catalina 22 Henderson Bay, NY
Has anyone ever seen a jib where the panels run parallel to the leach? If so why would it be constructed that way? Someone the other day said they had seen one that looked like that. Thanks
Dale
Ross
Jun 15, 2004
14,693
Maybe on a small sail but a large sail wouldn't be able to keep its shape cut that way.
RichH
Feb 14, 2005
4,773
Depends on orientation of the threads in the fabric (warp and weft) or laminate orientation, and which is the stronger versus direction of the intended stress.
Parallel panels along the leech, luff and foot .... are common in radial patterned sails. Radial, et al constructed sails usually have little 'adjustability' in the shape, as the shape you design/build is the shape you get; not like a cross-cut sail where stretching out one side will alter the general shape of the sail. In radial panel construction the orientation of the strongest 'set' of fibers or films/laminates is along the 'edges' of the sail .... the benefit is that the sail only very slightly stretches out of shape when fully windloaded; it generally retains it set shape all through its target windstrengths.
Nov 22, 2008
3,562
Endeavour 32 Portland, Maine
This was the common construction for cotton sails where the material had much more stretch and needed the help from the seams.
