Jib blocks
Oct 27, 2011
55
O'day 25 Dauphin
Does anyone know if the jib blocks located along the deck of a 25 are of any real value, or is their value limited because they are stationary?
Nov 9, 2012
2,500
Oday 192 Lake Nockamixon
Adjustable jib fair lead blocks are always desirable as they will allow you to adjust the power of the headsail.
May 31, 2004
858
Catalina 28 Branford
I found that the stationary jib blocks on my Oday 23 were perfectly adequate for most sailing conditions with my 100% jib. However, if you race or are a tinkerer, movable sheet blocks are a must.
I now sail with a 135 Genny on roller furling, and I use the moveable blocks further aft. I think they were meant for the spinnaker (which I don't have). I find that I don't move the blocks anyway; I sail in fairly consistent conditions and I find that I'm either single handing and don't have the time to futz with the blocks, or I'm with my wife and guests and I don't have the room or inclination to do so.
Whatever floats your boat....
Oct 27, 2011
55
O'day 25 Dauphin
The reason I ask, is that I removed them when redoing the deck and haven't convinced myself of the value in putting them back on.
Ward H
Nov 7, 2011
3,843
I sail with my 100 (or maybe its a 110) jib using those stationary blocks. I think they are better than running my sheets back to the genoa track but they are not perfect. As Brian said adjustable would always be better.
The reason I haven't installed a track yet is who am I to know where the track should go and how long it should be. Probably money would be better spent on a new jib.
I just got a new main which will be put on tomorrow. Then a new traveler is lined up for the spring.
Then I might be ready for a new jib, then jib track.
