G. Bean
My take on your follow up pic while on a beat. My first thought was as Don suggests to try moving the car forward. It appears the foot of the genoa is much flatter than higher up. The effect of moving the car forward would be to make the shape of the genoa more uniform throughout its hoist. This necessitate an adjustment of the sheet. Small car adjustment make dramatic changes in sail shape so these adjustments need to be made in small increments. This would also serve to allow you to sail higher and re-trim the main for the new course.This is all part of the game of sail trim. Each adjustment in turn affects others. Add to this the constant change of wind speed and direction and you can easily understand why sail trim is an on going never ending game.To Don's comment about sheeting after a tack. The first 85% of sheet needs to be taken in as quickly as possible. After the helm completes his tack the boat is not sailing its highest and the sails need to be set in a slightly cracked off position. As the boat builds speed the helm will start to head up to the new course. As this happens the jib trimmer continues to bring the sheet in to accommodate the new course. The last 15% of adjustment may take up to 60 seconds as the boat settles into the new tack dependent on wind strength.
