James River and the Chickahominy
3,562
Endeavour 32 Portland, Maine
Responders to my last thread were right. Moving certainly does improve the mood. Of course, that’s been pretty much the central theme of the last two years of my life.
I took Buck420’s advice, given while putting two new gold crowns on my rear lower molars, and ran up the James River. It started as a beautiful day with wind that came and went and shifted directions so I alternated between sail and power several times. Passing the huge Newport News shipyards was impressive.
By the time I passed the reserve fleet of mothballed ships, the wind was stiff. I passed Jamestown Island in short, current whipped, freshwater waves. There wasn’t a lot of spray but I was glad to get into the shelter of the Chickahominy.
The holding ground above the bridge is great. I put out an anchor trip line because of seeing cypress trees and snags inshore and could hardly get the anchor broken out in the morning with the trip line. The wind during the night had buried it deep.
The Chickahominy is certainly worth the trip up the James. The western shore is mostly wildlife preserve and it is probably the most beautiful a place I have seen in the bay area. I saw at least a half dozen to eagles and there seemed to be some kind of Match.com event for the birds going on in one tree.
The wind started to blow early and cold. I intended to explore the river as far up as I could run and spend a couple days there but it was cold motoring into the wind and I knew from Google Earth that I would encounter civilization around the next bend. I’ve spent a lot of time hanging out and exploring beautiful creeks and marshes in the past months but done very little sailing. The prospect of a sleigh ride back to Hampton became irresistible so I set the sails and turned around.
It was indeed a sleigh ride, winds gusting to 30 knots according to the buoy reports. Much of the time I was a knot over my best speed under power and it was free.
There is always some risk going out of the marked channels in the bay area due to possible obstructions in the marked fish trap areas. The odds are on your side though and it’s tempting to take short cuts. I was on a warp speed beam reach just south of Jamestown Island running along just outside the channel when I saw the top of a piling flash by about 20 feet away. Only about six inches was showing in the troughs and I could tell by the waves that it was fixed to the bottom. That gave me religion, I tell you. I’ll be staying inside the marked channel lines for at least three or four days now.
I spent the night in Hampton again and am about to move down to Portsmouth.
Sep 15, 2009
6,244
S2 9.2a Fairhope Al
good morning Roger...did you happen to pass Jamestown settelment on your way.....there is a tall ship called the Susan Constant docked there that is worth the loooking ...hope you didnt miss it ......have a safe and good day .....
regards
woody
Apr 22, 2001
497
Hunter 420 Norfolk, VA
Glad you got up to the Chickahominy, Rodger.
It's one of those sparsely populated, off the beaten track, places that is relatively unknown to sailboat cruisers, and especially nice in the Summer when water lilies, etc are blooming, and the clean, fresh water is warm and has no nettles, etc.
Sadly, the new 48' high rise bridge which was built at the river's entrance a few years ago, (replacing an old swing bridge), now limits access to only powerboats and smaller sailboats.
BTW, all, Rodger was a great patient, who, I can certify, is now, an even more valuable "Featured Contributor" than he was prior to Tuesday.
Buck, really nice thing you did for Roger, thanks for keeping him going! :)
Nov 22, 2008
3,562
Sadly, the new 48' high rise bridge which was built at the river's entrance a few years ago...
It's 52 feet according to Active Captain and was showing over 55 when I went through.
Oct 17, 2011
2,809
Ericson 29 Southport..
Yep, yer a goodun Buck.
Cruise on Roger.
(And think hard about that voice in your head that says you need a companion)..
a thought...
CalebD
Jun 27, 2006
1,479
Tartan 27' 1967 Nyack, NY
Who doesn't love saying "Chickahominy"?
Sounds like a lovely excursion.
Apr 13, 2009
53
Irwin 33 St Pete, FL
I believe the Pride of Baltimore is currently in Dry-dock in Portsmouth. Perhaps worth an hour or two of your time to visit her if you are still there. In any case I like Portsmouth far more than Norfolk.
