Jacking Hunter 20 off trailer
Apr 13, 2020
21
Hunter 20 Canyon Lake
Trailer. Check tires for dry rot. Suggest replacing bearings and racers using marine compatible grease. If brakes , check that completely. Check whelcfenderscare secure. Check winch stand and the other leaf spring. Check trailer light. Check winch strap
Thanks Dave! Will do!
Thank you! What is Cold Galvanizing compound?
Should I pick some up?
It is a spray paint with zinc flakes. The zinc acts as a sacrficial anode and helps slow the rusting of your trailor.
