Jabsco Toilet
419
Hunter 33 Metedeconk River
As I winterized last fall, I noticed that the pump cylinder on my toilet has a horizontal split on the lower horizontal section. A new cylinder is about $50 and since the unit is 10 years old I should probably replace the internal rings and washers etc. A totally new unit is about $140. I am pretty handy and will do the work myself. The question is, am I just better off buying the whole new unit or just replacing the parts I need? Thanks.
Tim R.
May 27, 2004
3,626
Buy a new Raitan PHII. A much better toilet. You may be able to reuse the bowl and just buy the Raritan pump assembly and base.
Sep 24, 2006
236
Sabre 36 Express Chattanooga, TN
Or you can purchase the pump assembly without the bowl. That's what I recommend.
May 23, 2004
3,319
I second the Raritan PH II. I trashed my Jabsco piece of crap and put the Raritan in there. I do not regret that one bit!
