Jabsco to Raritan conversion
Bob F
I'm considering replacing my Jabsco manual toliet with a Raritan manual toliet on my H376. Has anybody done this? I'm concerned the attachment base will require significant modification. Thanks. Bob
shaun
Did it on a 37.5
I have a 95 37.5 so I am not sure what might be different.... I needed to redrill the supporting bolts at the base and cut the pump handle down by 2 inches so that the aft door could open and close.... it is a tight fit but it worked and we are happy that we made the change.... hope that helps.
A
Andy
See photo forum on 340
The Jabsco in our 340 was replaced with PH-II. The new head came with a new base and some new holes had to be drilled but otherwise it works.
Jun 4, 2004
255
Hunter 376 Annapolis MD
I did it on a 376
I changed to a ph II. Easy job, just had to rotate the fixture and drill new holes. Also, ask Raritan for a straight waste outlet instead of their right angle one that comes with the toilet. The waste hose fits right into it. Initially, orient the toilet so the waste connection matches up and then drill your holes. Allan
Mark Juetten
How did the handle fit
Did the throw of the pump handle create any problems since the Jabsco pupmed straight up and down and the Raritan has a horizontal arccomponant to it. Did you keep the handle on the left side as you face the head. Thanks
Sandi
Just did it
on our H36. Should have done when we bought the boat! Peggy was right. Put in a Phii It wasn't difficult, added a strainer to the inlet hose. I am still getting used the handle as it sticks out a bit. You won't regret it.
Jun 4, 2004
255
Mark, your Qs
>Did the throw of the pump handle create any problems No, I just keep it in the up position and it does not interfere with the door opening. >Did you keep the handle on the left side as you face the head. Yes, thats why you need to rotate. The factory ships it with the handle on the right, but it is made to have the handle on either side. It is a simple change. Allan ps Don't know why the emoticons showed up on the posting, I guess it is magic.
Mar 20, 2004
1,753
phII
Sandi, did you use the marine or the home bowl on your h36 conversion? I'm getting ready....
Bob F
Drilling Holes
You folks mention drilling holes to mount this toliet. Please clarify, am I drilling holes into the boat? Or into the base of the toliet? I assume the toliet is held in place with a bolt & nut. I always get nervous drilling holes in my boat down below the waterline (LOL)!
Dec 2, 1999
15,184
Usually lag bolts
Bob: Normally the toilet is held in place by lag bolts. If you remove one of the existing ones you will see how it all works. You may get lucky and only need to drill one or two holes, that has happened to me in the past.
Jun 4, 2004
255
holes in 376
In the 376, you drill new holes into the raised area that the toilet sits on and install lag bolts. There is empty space under the raised area so if you drill down about an inch to get thru the raised area you will not get near the hull. Unscrew one of the rear lag bolts that holds the current toilet and you will see the clearence you have. Also, its worth adding a little strainer upstream of the toilet pump. Its simple to do and keeps the inside of the rim of the toilet clear for good water flow and to avoid odors. Allan
