last year I rebuilt my macerator with the housing kit including impeller, bolts and gaskets.  when it started leaking a few days ago, I removed it to inspect.  the long bolts were tight but the short ones were slightly loose but not so much that it was the obvious problem.  the gaskets were pretty wet and worn.  everything else seems fine  so it looks like i just. need new gaskets and some good loctite.  my question re the gaskets... the replacement kit gaskets seem pretty thin and papery.  are there more robust ones available? can I use a  gasket maker like permatex instead of or in addition to the standard paper gasket?
