I just bought a boat with a new Jabsco macerator conversion system installed. The installer removed the vented loop from the head water supply line. It appears from the installation manual that the vented loop could cause loss of prime on this pump. I suspect that was why it was disconnected. Is there any solution to this problem ? Am I better off the to just toss it and install the Raritan ? I have very little tolerance with Jabsco products.
The boat has a 30 gallon holding tank with deck pump out, and macerator pump/discharge.
thanks, Bob
thanks, Bob
