jabsco electic head
llogue
Mar 18, 2006
12
Hunter 33 Erie, PA
We are no longer getting water in to the top part of the bowl-just some in the bottom when we push rinse.
Dec 2, 1997
9,010
- - LIttle Rock
Sounds like intake impeller failure
Impellers do have a finite lifespan that can be shortened to about 30 seconds if you make the mistake of keeping the intake thru-hull closed and adding water to the bowl with a cup or the shower head. That is, if you're sure the intake seacock is open. Replacing it will be fun (NOT!), because to replace it in a Jabsco, you have to take the whole pump apart to get to it. Which model is your Jabsco?
