Ivan, How to disconnect the boom joint
siggib
May 31, 2004
18
Hunter 31_83-87 Tampa
Regarding Hun 1984 31'. Well, Ivan is on track for Tampabay. I Lucked out with charley and frances. I took already everything of the deck. This time I would like to store the boom below deck. I just can get the joint disconnected. It seems to be secured with 2 stainles rings. How does this work ? Quick response is appreciated. Thanks Siggi
Jun 4, 2004
38
Hunter 31_83-87 Ponce inlet FL
Here's how
You first have to remove the clips,..pretty easy, then you need to lift the boom from the rear (pretty High) and as soon as it gets hight enough the boom will release as long as you are pulling it towards aft at the same time. KEEP THE CLIPS AND THE PLASTIC ROUND GOLF BALL SIDES as they are HARD TO FIND. I am waiting here for my THIRD Hurricane here in Ponce Inlet too by the way,..GOOD LUCK Fast enough?
Siggi
Thanks Mark
Thats what I needed to know. Thanks. Hope Ivan continues west. good luck
