It's very cold and our heater isn't working. Any webasto hel
Feb 19, 2015
1
Piewiet 1100 Gregg Neck boatyard
Does anyone know how to troubleshoot a Webasto LO 2305? It is 14° and I will take any help that is offered. I only have 2 hands. The old lady's in bed pregnant and we need to fix our heater asap. We are full-time live aboards.
Feb 20, 2011
8,062
Re: It's very cold and our heater isn't working. Any webasto
Have you performed a search of the site using the blue search tab near the top of the page you're viewing?
Good luck.
May 7, 2012
1,625
Hunter e33 Maple Bay, BC
Please call a dealer immediately. I found 8 within an hours drive of your boatyard.
http://angebote.webasto.de/Public/LtRFPsNew.aspx?cgroup=4
Then maybe comeback and search this site for assistance.
Good luck.
Oct 24, 2010
2,405
Hunter 30 Everett, WA
Check input voltage at the heater unit itself. Corrosion on connectors is the bane of these things. Go get a cheap digital multimeter if you don't already have one. It will pay for itself just checking flashlight batteries if nothing else. Check the fuel filter if you have one on the heater.
Here's a link to a cheap $6 meter that will work just fine for occasional use:
http://www.harborfreight.com/7-function-multimeter-98025.html
Harbor Freight stores always stocks these.
Ken
Oct 24, 2010
2,405
I should have said
Be sure to check DC voltage between the positive and negative connections at the heater while it's trying to start. It may be necessary to select it off then back on to get this condition.
Ken
