Please note, I found this diagram on the web. It gives the basic idea of how my set up is. My engine is a Universal M20.
This winter spring I changed out my cutlass bearing. So in order not to mess up the transmission I needed to do a re alignment. Well I found that my engine mounts were bad so I ordered replacements and ventured into switching them out. One of the important steps is to remove the connecting parts for the exhaust so the engine can be lifted. In doing so the pipe with the line entering that brings water to the exhaust just fell apart from rust and corrosion.
My question to those that have a similar set up is "why can't the raw water that mixes in the pipe not be sent straight to the Vetus box. This would eliminate the manufacturing of a connection. Would this work and maybe someone can explain why or why not. Thanks in advance.
