ISO teak wood, hinges miscellaneous hardware...
Dec 21, 2019
29
MacGregor Venture 25 Galveston Island
I have a Mac 25, I need some life lines that are better than what I have now they're pretty much junk, I need a rudder for the sailboat or some parts that I can make a good one, I'd like to pick up on an aluminum fuel tank at least about a 30 gallon tank I suppose... Miscellaneous hinges, nuts, bolts, washers, a point screws Phillips flat head, Allen it doesn't matter I need to build a collection.
1,109
For stainless fasteners of genuine 316 alloy at reasonable prices, try
McMaster-Carr
I highly recommend 316 stainless alloy. It is only a few pennies more than “regular” 18-8 or 304, and it is much less likely to corrode In a salt water environment.
Dec 21, 2019
29
McMaster-Carr
You already knew where I was planning to be! :)
