If you had a stainless tube where the outside diameter would fit into the upper and lower holes in the casting and so that the inside diameter would accept the stainless pin, then you would remove the slop, straighten it out and probably eliminate some failure down the line. I believe LeFiell Mast Co provided the spars and spar hardware for Islanders and they are still around out of California.
