Is This Cheesy, Stupid, or Just Plain Dangerous
Sep 2, 2011
1,041
Hunter 27 Cherubini Alum Creek State Park
I tried to find an elegant solution that didn't cost an arm and a leg...
Mar 29, 2017
576
Hunter 30t 9805 littlecreek
Don't get stung by that yellow jacket. What do those Rg 6 connections do. Maybe a weather head from home depot
Jan 7, 2011
5,906
Oday 322 East Chicago, IN
I would get a cap on each of those to keep water out when not connected to the cables, other than being a bit of a trip hazard, it should work.
I did something similar for my cable TV hookup, but I was able to put my connection in my anchor pan. That way it is out of the weather, and pretty much out of the way.
Greg
Mar 29, 2017
576
Do you have a mast top vhf antenna for your radio. I bought adapters from radio shack and connect to tv when not using marine radio. Like at marina or at anchor
Sep 2, 2011
1,041
Greg
Do you run the cable across the deck to get it to the mast?
Sep 2, 2011
1,041
Yes, my vhf antenna is at the masthead and my tv antenna is on a spreader. You get tv reception thru your vhf antenna?
Jan 7, 2011
5,906
My A/C shore power connection is my anchor locker. So I have my cable TV cable taped to ,y shore power cable, and when I hook my shore power, I also attach my cable tv cable to a fitting I mounted in the anchor locker, and runs to the TV.
I don't have anything running to the mast.
Greg
Mar 29, 2017
576
Yep great reception sometimes when I'm far from civilization I need a 12v vhf amplifier I bought at Wal-Mart it's a inline amp with cord going off that had a little 12v transformer on end. Cut transformer off and installed cigarette lighter type end
Sep 2, 2011
1,041
Geez...I coulda saved $80 on the flying saucer! Oh, well. I understand the trip hazard, but I can still pull the cables out of the thru decks far enough to lay them flat. I wanted to put them thru the mast step, but with 4 sheaves and their r I forcing ribs, there just wasn't any space to drill 2 holes.
