I found this picture on the site and noticed that the sole has the same soft/rotted spot as my H34, right between the engine and the ice box, at the tip of the panel. (Lower right corner of the picture)
I'm in the process of replacing all the teak and holly and was wondering if there is some issue which is causing this problem.
Leakage through the companion way? Ice box leakage? Water in the bilge or below the sole?
