David
Ok, I have a Catalina 30 TRBS which I just put back in the water after a new bottom. In 15 knots of steady wind, I was sailing on a broad reach at 7-7.5 knots STEADY and peaks of over 8. Average speed after 3 hours (motoring and sailining in & out of marina combined) was 6.9 knots. I know the max theoretical hull speed is 6.7 knots. Can a new bottom really make that much difference? As a comparison, I was able to motor comfortably (engine at 2400) at 6 knots even. As far as I can tell, the knot log is reading accurate. Also, Many of you here have mentioned a "flutter" in the wheel when using a 3 blade prop above 4.3knots. I experienced the same problem, but with the new bottom, the "flutter" is TOTALLY gone. Any gurus wanna comment on this one por the speed increase?Thanks
