Is there a Y valve?
1,981
Catalina 310 #185 Quantico
The drawing for the 310 plumbing in the manual shows a Y valve between the output of the toilet and the holding tank or macerator. I don't think I have on my boat (#185) and that the toilet goes directly to the holding tank. Is that correct?
paulj
Mar 16, 2007
1,361
Catalina 310 Anacortes,Wa
rpwillia
Hull number 192 does not have a Y valve installed, but I do have a picture of one in the manual.
The discharge line from the head goes to the holding tank.... then if you want to pump out the holding tank over board, open up the thru the hull valve and turn on the macerator pump.
Of course everyone knows when you can discharge waste overboard:confused:
paulj :troll:
Sep 29, 2008
1,981
Thanks
I kinda figured that was how it was done. Makes a little more sense.
Jul 1, 2009
221
Catalina 310 Sydney-Pittwater
My hull No 149 has it. It can direct discharge into holding tank or straight overboard (or, if you get it wrong, directly into the boat).
If your boat has it, follow the manual's/diagram's instruction as the valve seems to operate differently, ie. the lever vs flow direction, to the thruhulls.
Dec 25, 2008
1,580
catalina 310 Elk River
That's weird? 83,185,192 doesen't have it, but 149 does? wonder if they had different regs for international sales?
Sep 29, 2008
1,981
Could depend on the market
You know how all those Americans are always wigged out about stuff.
There is also a philosophical thing at work here: does everything go into the tank first even if you go overboard, or should it go overboard first if it isn't going into the tank. This is a MAJOR consideration in your plumbing. West Marine likes the "everything through the tank" method. I think that's absurd, why stuff anything into the tank that doesn't have to go there? Why require a macerator for overboard discharge ever if it can just go directly? http://www.westmarine.com/webapp/wcs...ding-Tanks.htm
If you have a Y valve, why not put it where it can do the most good? Between the head and the tank?
May 3, 2008
190
Catalina 310 Catawba Island
Hull number 118 has a Y valve - I have it wire tied to send to tank and the macerator breaker tied off - both done to comply as best I can with Canadian regs -
