Hi Don:
Here's one way to check possible locations for your transducer. While tied to the dock, measure the water depth using a line and weight. Put some water in a plastic bag and close it securely. Set the bag on the inside of the hull, press the transducer into it lightly and power up the depthsounder. If you see a nice clear return and the depth matches your line sounding, the bag is in a good location. If not, move the bag around on the inside of the hull until you do, kind of like a "reverse sonogram". Once you find a good location, install the transducer using your favorite method.
Warning! The location you finally select must be low enough in the hull so it remains below the waterline when the boat is heeled but not so close to the keel that the signal could return through it and show shallower water than the true depth. It's no big deal if you're just trying not to run aground but it may be misleading if you're trying to use a charted depth contour for navigation. Good luck.
